Revolvo’s Split Roller Bearings details
Revolvo’s SRB split roller bearings have been specified as part of the diesel electric propulsion system for a refurbished icebreaker that has recently been re-engineered in the Ukraine. The SRB split roller bearings were specified due to their ability to be quickly changed in-situ, preventing unplanned layovers or dry docking, in the event of a bearing replacement being required whilst the vessel is in service. The SRB split bearing design – totally split to the shaft – allows simple and fast installation and easy replacement – up to 90% faster than solid roller bearings used on marine drive propulsion systems.
Revolvo split Bearing
The SRB split bearings are being employed as support bearings for the intermediate shaft between the icebreakers diesel engines and the generator units. In contrast to conventional vessels with fore or amidships mounted main engines, and long propulsion shafts connected via couplings to propellers, the diesel-electric propulsion system uses several medium speed diesel engines to drive generator units providing electrical power for the vessels electric motors that drive the ship’s propellers.
Over the last few years the move to diesel-electric propulsion systems has accelerated as the benefits of the system have been proven. It is now estimated that the utilization of diesel electric marine propulsion systems has doubled over the past 3 years. The benefits include reducing the overall size of the drive system, with smaller engine rooms as it’s possible to replace large slow speed engines with multiple smaller generators; reduced noise and vibration as there is no need for long fixed drivelines; increased efficiency reducing fuel consumption; and increased flexibility as power can be shared with multiple devices such as bow thrusters, pumps etc, along with the main propellers.
The specification of Revolvo’s SRB split bearings on the icebreaker is the latest in a long line of successful installations for these bearings in the arduous marine operating sector. The SRB split roller bearings offer proven reliability and a number of key operating benefits. First, easier bearing fitting: typically fitting a split roller bearing takes only about 10% of the time taken to fit an equivalent solid bearing in a trapped location. Second, the ability to inspect the bearing in situ without any major disassembly. Third, the ease and speed with which the bearing housing of a SRB split roller bearings can be replaced if it’s required. Fourth, the ability of SRB split bearings to perform reliably in aggressive environments, due to the performance of the sealing systems available to protect the bearing units.
The design of Revolvo’s SRB split bearing allows the shaft to be supported by the lower section of the bearing; whilst the upper section can be removed, allowing simple inspection or servicing without drive or shaft removal. This intrinsic feature is extremely valuable, generally, but especially regarding large machines, where sheer weight and size can be a barrier to fast and effective servicing. It also allows for faster bearing replacement, which can save continuous-type applications such as Marine propulsion systems a lot of costly downtime.
Revolvo manufactures its SRB split bearing housings, and support pedestals in tough 250-grade grey cast iron to ensure maximum strength and durability of the product. In addition, as part of its specialized service for SRB, the company manufactures corrosion resistant stainless steel housings, where conventional materials do not offer sufficient corrosion resistance. The latest in this series was produced for an underwater application, where the split roller bearings have to operate totally submerged in clean water without any risk of corrosion contamination. This design is a synergy of stainless steel and specialized sealing, the latter, being Revolvo’s special split and sprung garter seal, has been well proven over many years in submerged applications.
Revolvo Ltd, Unit 4, Yorks Park, Blowers Green Road, Dudley, West Midlands, DY2 8UL Tel: +44 (0) 1384-245370 Fax: +44 (0) 1384-245371 Email: Adrian.Menzies@Revolvo.com Web: www.revolvo.com
Source: Process and Control Today
GGB自润滑轴承替代滚动轴承
GGB自润滑轴承替代滚动轴承(0)
This article, press release or announcement is translated from BearingNEWS (www.bearing-news.com) publications and adapted for the Chinese bearing industry professionals. << Replacing Roller Bearings with GGB Plain Bearings >> 当今GGB轴承技术提供的先进滑动轴承与滚动轴承相比具备很多优势。当今GGB轴承技术提供的先进滑动轴承与滚动轴承相比具备很多优势。 除了它们的简单设计和成本效益,滑动轴承提供更大的负载能力,更大空间,重量更轻,更紧凑的设计节省重量。此外他们补偿偏差,减少边缘载荷和抑制噪声和振动。因为它们不包含运动部件,轴承也提供更安静的工作环境,更可靠的性能,并且只需要很少维护。 这些优势是由设计工程师在广泛应用滑动轴承替换滚动轴承来实现的。这些应用包括风力涡轮机,农业设备,转向系统,空调压缩机,发动机摇臂,节流阀,变速箱和传动系统,和头目,其中。潜在应用包括海上浮式生产储油系统,制动机构,发电机和起动机。 滑动轴承也不是适合所有应用。尤其是在需要超低摩擦和/或高精度轴位置。但是在涉及高载缓慢的振荡运动中滑动轴承就显示出了优异性,因为滚动轴承的滚动部件脱落可能会导致过早失效。 用GGB轴承取代传统的滚动轴承可以给用户提供技术和竞争优势。更大的接触面积提供高承载能力和抗疲劳破坏,冲击和边缘载荷。轴承的摩擦特性也抵抗惯性和高速滑行,滚子轴承的主体,他们容忍偏差优于许多滚动元件设计。 紧凑的整体结构和较小的外壳,节省空间和重量。简单的压入配合几乎消除了安装的潜在损害。转换为滑动轴承还可以降低部分成本,低风险装配。 完整替换滚动轴承与普通轴承的文章,请点击 http://machinedesign.com/article/plain-bearings-outperform-rolling-element-bearings-0407 更多信息请联系 china@ggbearings.com
EMT bi-metallic bushing
EMT bi-metallic bushing(0)
EMT bi-metallic bushing  is suitable for high load, lower speed oscillation & rotation movement. EMT Brief Description EMT bi-metallic bushing is formed from steel strips with alloy lining material. The alloy lined surface can be machined oil grooves, holes, formed Indentations etc according to different application. It is suitable for high load, lower speed oscillation &
EX Tri-layer low maintanence plain bushings
EX Tri-layer low maintanence plain bushings(0)
EX Tri-layer low maintanence plain bushings has good physical & mechanical properties, also has certainly chemical properties. This material has good machining performance if required. EX Brief Description EX tri-layer low maintanence plain bushing have a base of lower carbon steel, onto which a porous bronze layer is sintered. Acetalcopolyer (POM) is impregnated into the
The largest bearing cage manufacturer in China
The largest bearing cage manufacturer in China(0)
Liaocheng Xinxin Golden Empire Bearing Cages Technology Co., Ltd is a professional bearing cages manufacturer, and it is famous for its large scale and premium brand. Since foundation in 1985, GEB had been developed steadily. Now GEB has thousands of workers, construction area is 99500㎡, total assets is 232 million RMB, and annual sales is
LYC launched the domestic most complicated rolling mill bearing
LYC launched the domestic most complicated rolling mill bearing(0)
On July 7, LYC Bearing Corporation launched the domestic most complicated high-precision shell ring rolling mill bearing and delivered to a domestic well-known heavy machinery enterprise, thus became the only bearing manufacturer able to produce this kind of bearing. According to Sun Jianxiu, deputy general manager of LYC Bearing Corporation, the bearing has a diameter
© 2016 BEARING NEWS All rights reserved.
