Schaeffler CTO Prof. Peter Gutzmer discusses the drives of tomorrow at the MTZ Conference in Wolfsburg
Key Technologies for the Efficient Drive Trains of Tomorrow
“The Drives of Tomorrow” was the theme of the MTZ’s 8th conference held in Wolfsburg. Engine developers and automotive engineers came together here to exchange ideas, with the main focus being placed on innovative solutions for tomorrow’s automobiles, which will be shaped by globalization, the availability of resources, and legislation on emissions. The automotive industry and its suppliers are working on solutions to these challenges. In addition to the increasing trend for electrification, the optimization of drive trains based on internal combustion engines as a complete system is also a focal point, as they are set to retain their dominant role in individual mobility.
prof. Gutzmer
In his keynote speech “Enablers and Key Technologies for Efficient Small Engines”, Schaeffler CTO Prof. Peter Gutzmer addressed the conflicting priorities that have to be dealt with in modern engine development. „Small engines are both a marketable solution and a technical challenge at the same time. Smaller means less engine capacity and often fewer cylinders, less weight, and less friction – but above all, it initially means less comfort and inferior dynamics as well. These are the problems we have to solve“, Gutzmer explained. “The performance and the running characteristics that are prevalent today have mainly been defined by large-capacity engines with a high number of cylinders. In contrast, modern „rightsizing“ drives with innovative components are just emerging on the market.“ For instance, two-cylinder engines used in small cars, three-cylinder engines used in compact cars, and four-cylinder engines used in high-end cars all deliver respectable performance and are therefore increasingly in demand today. The trend for increasing specific engine performance is set to make significant advances here.
The technologies and components playing the decisive role include variable valve control systems, turbocharging, increasingly complex thermal management systems, and a range of solutions for vibration damping. We also have the task of minimizing friction and reducing weight to a greater extent, and of considering all these individual factors together in order to achieve an optimized, holistic approach.
Key word: Variable valve train
The variable control of the valve train is a key technology for optimizing the combustion process. There is a range of individual solutions for this, which are specially designed to suit the relevant design features and requirements and are developed as modular systems. These range from variable cam phasing units and switchable valve train elements through to fully variable systems such as UniAir.
Keyword: Turbocharging
Downsizing is a key trend that is accompanied by turbocharging, which is enjoying especially strong growth in gasoline engines. Turbochargers must be able to respond well and allow precise regulation, as well as requiring a high level of thermal stability, but modular approaches to manufacturing must also be taken into account from the start in order to allow them to be flexibly adapted to the engine and the vehicle.
Keyword: Thermal management
A further field of activity when it comes to the thermodynamic optimization the internal combustion engine is thermal management. Intelligent, processor-controlled modules for regulating the cooling circuit make it possible to shorten the warm-up phase and thus offer significant advantages, especially when it comes to cold starts according to the New European Driving Cycle. They also ensure that the temperature balance is precisely controlled and that the engine operates in the optimum temperature window.
Keyword: Vibration damping
Downsizing and downspeeding initially mean a deterioration in the vehicle‘s NVH behavior and thus pose new challenges for the combination of engine and transmission. Balancer shafts in the engine can provide an improvement here. A further enabler for these engine concepts are damping elements used at the interface to the transmission. Schaeffler’s innovative centrifugal pendulum-type absorber, which ensures that the desired level of comfort is achieved for drive trains with both manual and automatic transmissions (double clutch and torque converter types) is effective here. Rotational irregularities in the crankshaft can also be reduced through the use of damping elements that employ the dual mass flywheel principle in the belt drive.
Keyword: Friction reduction
The painstaking reduction of friction at numerous points in the drive train also makes a significant contribution to the optimization of drive trains based on internal combustion engines. Comprehensive knowledge and extensive detailed work are the key to achieving this. For example, surface technology that allows friction, consumption, and also wear to be reduced in a cost-effective way through the use of specific coating systems, provides an innovative range of options.
“At Schaeffler, our core expertise is in the field of mechanical systems, and we create holistic solutions by combining comprehensive understanding of the entire vehicle with interdisciplinary thinking and working methods and innovations”, explained Prof. Gutzmer. “This allows us to master increasingly complex technologies and ever-shortening innovation cycles, and thus to offer key components for efficient future mobility.”
source: Schaeffler Technologies AG & Co. KG
轴承和轧制设备零部件行业的交汇点
轴承和轧制设备零部件行业的交汇点(0)
2019年, BearingNEWS将与汉诺威工业博览会携手在汉诺威博览会、伊斯坦布尔土耳其国际工业展览会、上海亚洲国际动力传动与控制技术展览会和孟买的轴承世博会期间,举办轴承世博会及会议、展馆和电子商务会议。 轴承世博会概念 国际轴承世博会及会议是一个独特的活动概念,包括展览,轴承会议,展馆和电子商务会议设施 – 服务于广泛的行业专业人士,分销商,原始设备制造商和可靠性测试工程师。每个活动都是根据2019年四个不同主办国当地参与者的要求和需要设计的。 轴承世博会旨在为企业之间创造协同效应,通过在全球汉诺威展览会期间提供设施建立网络 ,及在会议期间分享最新的市场知识,创新产品和服务; 这些均适用于轴承,动力传动,运动和驱动,润滑和维护等领域。 为何要参与轴承世博会活动? 1. 同一个地方与“本土和国际”重要的轴承公司和PT/MC行业的公司联系 2. 通过赞助机会宣传贵公司,产品和解决方案 3. 拓展您的分销商网络,产品/解决方案组合及使供应商基础多样化 4. 与专业人士分享观点、知识及讨论与行业有关的话题 5. 寻找适合您提供的解决方案和产品的新客户 6. 从国际主旨演讲者中获得新观点和有用信息 7. 参观有潜力的公司并享受汉诺威、伊斯坦布尔、上海和孟买之旅 参展商简介 轴承和PT/MC制造商,分销商,润滑剂公司,维修专业人员,设备制造商,工业解决方案供应商,工程服务和组织 访客简介 制造商,分销商,可靠性测试和维护工程师,机器制造商,汽车、钢铁、水泥、采矿、能源、食品和饮料、非公路和海洋等工业的专业人士 会议话题 关注当前市场形势的商业和技术研讨会;轴承供应商开发和质量控制流程; 重型应用轴承故障原因分析;关于工业物联网的技术见解;精密工程技术和新技术 电子商务会议 在孟买、伊斯坦布尔和上海举行的电子商务会议期间,与来自世界各地的轴承和动力传动公司、制造商和经销商的决策者们会面。 线上轴承世博会 所有轴承世博会和会议的实体活动及存在于我们网络中的公司均可在线上展览会门户网站www.bearing-expo.com上查询。 公司还可单独注册线上轴承世博会门户网站,随即开始一年365天推广其公司、产品和服务。 电子商务会议的匹配项目由线上轴承世博会门户网站组织。 联系leslie@bearing-expo.com(邮箱) 或者浏览 www.bearing-expo.com/events(网站) 了解所有关于参与伊斯坦布尔、汉诺威、上海及孟买的展览会
第四次工业革命期间的轴承生产和分销
第四次工业革命期间的轴承生产和分销(0)
活动: 轴承世博会会议和电子商务会议 日期: 2019年3月15日周五 地点:伊斯坦布尔 展览会:土耳其国际工业展览会www.win-eurasia.com/en 报名: leslie@bearing-expo.com 网站:www.bearing-expo.com/events 组织者:BearingNEWS(轴承杂志) www.bearing-news.com 2019年3月15日(周五), BearingNEWS将与汉诺威工业博览会携手在土耳其国际工业展览会——欧亚地区最大的工业展览会期间,举办第二届国际轴承世博会及会议。土耳其国际工业展览会将有主要是来自土耳其、德国、伊朗、保加利亚、意大利、韩国和沙特阿拉伯的1500家参展商和75.400名访客。 全天的轴承博览会活动将于上午举办的轴承行业相关会议外进行,下午将继续土耳其和中国轴承企业的电子商务会议。主旨演讲将由来自德国、土耳其和中国的专业人士发表,并会同步由英文传译为土耳其语。该活动旨在成为土耳其轴承制造商、分销商和终端用户的最大交汇点。 该活动由土耳其政府机构支持来促进当地和外商的投资。该项活动也是一个可参观最大的区域性展览会并与土耳其的主要轴承公司、以及在电子商务会议期间生产或计划投资轴承生产的其他土耳其组织取得联系的独特机遇。 您可参与轴承世博会伊斯坦布尔项目,届时您可在轴承会议区使用定制的弹出式展台和滚动横幅,并在电子商务会议室内使用您专属的会议桌与土耳其的轴承公司举行私人会议。 为何要参与轴承世博会活动? 1.在同一个地方与土耳其重要的轴承公司和PT/MC行业的公司联系 2.通过赞助机会宣传贵公司,产品和解决方案 3.拓展您的分销商网络,产品/解决方案组合及使供应商基础多样化4.与专业人士分享观点、知识及讨论与行业有关的话题 5.寻找适合您提供的解决方案和产品的新客户 6.从国际主旨演讲者中获得新观点和有用信息 7.参观有潜力的公司并享受伊斯坦布尔之旅 联系leslie@bearing-expo.com(邮箱) 或者浏览 www.bearing-expo.com/events(网站) 了解所有关于参与伊斯坦布尔、汉诺威、上海及孟买的展览会信息。
上海亚洲国际动力传动与控制技术展览会上的轴承会议和匹配服务
上海亚洲国际动力传动与控制技术展览会上的轴承会议和匹配服务(0)
2030年前的轴承行业及贸易专题讨论 轴承故障的根本原因分析研讨会 工业物联网如何优化您的轴承应用研讨会 日期:8日11月2018年 地点:上海新国际博览中心,E2馆内J5展位 展示将会被同步翻译成中文 本次轴承会议由轴承世博会(BearingEXPO)和轴承杂志(BearingNEWS)及亚洲国际动力传动与控制技术展览会(PTC Asia)合作举办。请发送邮件至 leslie@bearing-expo.com赢取免费入场券参加本次会议! 上海,2018年10月3日——下届轴承世博会议将于11月 8日在上海举办的亚洲国际动力传动与控制技术展览会上召开。届时,会议室将设在轴承和电力传输2号厅。2030年前的轴承行业及贸易专题讨论、工业物联网如何优化您的轴承应用研讨会和轴承故障的根本原因分析研讨会均会为轴承行业专业人士提供商业及技术层面的讲解。 主题为“2030年前的轴承行业及贸易”的研讨会将由BearingNEWS 杂志的主编兼创始人Kenan Özcan 先生主持。主旨演讲重点关注包括制造业、分销和原始设备制造商、设备维护应用等方面的全球轴承市场现状。 企业被迫扩大其提供的服务范围,继续推进数字转型并维持价格结构。 与过去的30年相比,如今的轴承制造、分销及应用的变化更剧烈,只有那些适应性强的企业才能存活并成功将其品牌转移到下一代。 目前的技术发展、多变的市场驱动因素和行业动态正在导致顾客期待的大幅转变。 轴承分销商和制造商也被迫扩大其提供的服务范围,在维持价格结构的同时继续推进数字转型。 在Kenan Özcan先生的互动式主旨演讲中,他将会通过分析过去、定义目前的全球轴承行业现状来试图描绘未来的广阔前景,以期能在未来把握机遇 在轴承研讨会的第一部分还会看到来自山东宇捷轴承高级应用工程师程凯先生 ,他将在其30分钟的展示中重点讲解宇捷调心滚子轴承在钢厂的应用。 美国雷勃电气集团中国及太平洋地区总裁Roger Fei先生将发表题为“工业物联网如何优化您的轴承应用”的主题演讲。 工业物联网是塑造动力传动行业未来发展最重要的挑战之一。 Roger Fei先生将在其主旨演讲中总结这些正在发生的变化详情及实例。 “轴承故障的根本原因分析”研讨会将由Tribologia的轴承博士Per Arnold Elgqvist先生主持。 该研讨会旨在通过强调轴承故障的根本原因分析的重要性来提高维修的效率:确认其失败的根本原因和确保需求的纠正操作,以避免相同的原因导致更多故障达到精确维修,以及避免浪费时间和不必要的备件使用。 研讨会后,与会者将能够解释最常见的轴承故障原因,以便更容易地确定和理解需要的纠正措施,也会重视依据国际标准组织的15243标准理解不同轴承故障模式的重要性。 该研讨会还将介绍简单实用的轴承故障根本原因分析程序,并以互动方式展示一些相关的成功案例。 下载: 研讨会初步项目 下载: 2030年前的轴承行业及贸易专题讨论 下载: 轴承故障的根本原因分析研讨会 所有展示将会同步翻译成中文。因席位有限,请您提前发送邮件至leslie@bearing-expo.com注册报名吧。 匹配服务机遇 您可以查看下方文件中的参与者列表。如果您想参加我们的匹配服务项目,以便与更多公司会面并组织会议,请发送电子邮件至leslie@bearing-expo.com。 下载:参与匹配服务项目的完整参展商名单 关于亚洲国际动力传动与控制技术展览会 动力传动与控制技术展览会将于11月6日至9日在上海新国际博览中心召开。该展览会是一场国际电力和机械、动力传动、流体动力、机械零件、轴承及弹簧交易会。请访问www.ptc-asia.com网站赢取免费入场券。 注册报名请联系 Leslie 女士 电子邮箱:leslie@bearing-expo.com 轴承世博会网址:www.bearing-expo.com 轴承新闻杂志网址: www.bearing-news.com
轴承故障的根本原因分析研讨会
轴承故障的根本原因分析研讨会(0)
2018 年11月8 日的上海亚洲国际动力传动与控制技术展览会 展示者 Per Arnold Elgqvist 通过强调轴承故障的根本原因分析的重要性来提高维修的效率:确认其失败的根本原因 和确保需求的纠正操作,以避免相同的原因导致更多故障达到精确维修,以及避免浪费 时间和不必要的备件使用。 停止车间盲目地接受轴承故障为“正常”现象和简单替换轴承作为消耗品而不采取任何纠 正措施,仅仅是一句“让我们期待这个轴承能持久吧”。 解释最常见的轴承故障原因,以便更容易地确定和理解需要的纠正措施。 也会提及强调依据国际标准组织的15243标准理解不同轴承故障模式的重要性,因为在 很多情况下这些模式会清晰明确地指出故障原因。 该研讨会还将介绍简单实用的轴承故障根本原因分析程序,并以互动方式解决一些相关 的成功案例。 研讨会内容 初步判定:自热还是过早的故障? 我们为何要做轴承故障的根本原因分析? 首先,为了避免更多的重复性故障及意外 的停机。 其次,实施恰如其分的所需修复,即提高 效率。 减少意外及非意外的停机。 益处: 减少不必要的意外和非意外停机(设备综合效 率) 延长轴承寿命,增加其过程中的可用性(设备 综合效率) 通过减少故障成本及避免更多重复性故障来降 低总成本 举例:水泥厂的成功案例 故障成本: 40,000美元 生产价值损失:28,000,000美元 拥有相关知识后你会发现其实很简单。 很多情况下 ,在了解了轴承故障最基本的原因及不同的轴承模 式后,确定故障的根本原因并即刻理性指出所需的 纠正措施轻而易举。 简单分析的案例 立式泵 轴承: 6215 + 51115 滑润剂: VG460齿轮油 速度: 1500转/分 你还有10秒钟! 国际标准组织15243建立了轴承故障模式。 将描述下列故障模式: 疲劳:
2018亚洲国际动力传动展,加速推进产业智能制造
2018亚洲国际动力传动展,加速推进产业智能制造(0)
This article, press release or announcement is translated from BearingNEWS (www.bearing-news.com) publications or from China Bearing Commercial Community (CBCC) sources 作为动力传动行业亚洲第一、世界第二大的国际性专业展会——亚洲国际动力传动与控制技术展览会(以下简称:亚洲国际动力传动展)始终不遗余力地推进行业智能制造发展。将于今年11月6-9日在上海新国际博览中心举行的2018亚洲国际动力传动展以“驱动未来”为口号,主打智能制造,以行业最新产品、技术与解决方案助力实践“中国制造2025”。 随着动力传动制造技术与信息技术、智能技术的深化融合,行业智能制造水平和技术创新能力大幅提高,重大施工装备和技术成果不断涌现。行业正朝着创新、高端、智能、绿色的方向加速发展,全力迈向产业技术制高点。 在本届展会上,参展企业集中围绕“智能制造”推出最新产品,对接市场。继去年首次推出便大获成功的“智能制造示范展区”,今年更将重磅打造,以“工业4.0蓄势待发——智能传动与流体动力的智慧解决方案”为主题,积极邀请伦茨、ABB、弗兰德(西门子)、SEW、斯凯孚、舍弗勒、林德液压、雅歌辉托斯、布赫液压和穆格等行业大牌企业展示应用行业解决方案,以最新科学技术演绎魅力工业风。同时,此项与德国机械设备制造业联合会(VDMA)联合主办的展区还将配套举办智能制造论坛,让观众零距离获享德国传动工业领航技术。 此外,涵盖十大主题展区的亚洲国际动力传动展持续发力,为海内外企业拓展国际市场搭建独一无二的商贸平台。截至目前,已吸引土耳其、美国、西班牙、葡萄牙、日本、印度、罗马尼亚等多国企业参展,还有来自德国、意大利和韩国等的国家展团倾力献演。在液气密板块,有中意液压、油威力、华力液压、杭州爱力、国瑞液压、汉商、斯普瑞、华东油压、圣克赛斯、优瑞纳斯、韩独油压、北京铸通、南京机电、苏强格、兴明液压、镇江液压、凯斯特、津达、博顿、宁波华液、索诺、鑫潮、亿太诺、尼尔森、德氏封、KASTAS、司达行、埃雷特和意氟。在轴承板块,有安凯易、长城、达克、旭欧和雅高。在齿轮/电气传动板块,有弗兰德(西门子)、伦茨、邦飞利、麦尔、普瑞玛、应拓柯、诠世、瑞班、金龙、中德传动、安波、华力、兴达、光陆、特波、方力和中大力德。在带/链/弹簧板块,有盖茨、阪东、Contitech、麦高迪、SIT、东华、恒久、Wulf、永利百合、雷诺德、中益、希普拓、慕贝尔和力司百灵。 同时,随着中国推进“一带一路”建设,为动力传动行业带来了广阔的海外市场。企业积极拓展国际业务,加强沿线国家布局,收效显著。主办方表示,展会也通过各种市场渠道组织海外买家赴会采购,并得到了欧洲液压与气动委员会(CETOP)、德国机械设备制造业联合会(VDMA)、意大利流体动力协会(ASSOFLUID)、英国流体动力协会(BFPA)、韩国机械产业振兴会(KOAMI)、德国联邦采购物流协会(BME)和欧洲动力传动经销商协会(EPTDA)在海外观众组织上的大力支持。届时,预计将有来自全球80多个国家和地区的观众和采购商到会。其中,国内大型制造企业买家团数量将继续增长。2017年,亚洲国际动力传动展获得了上海电气、潍柴动力、宝钢工程、法兰泰克、兰石、阿特拉斯科普柯、凯泉泵业、上海港机、江淮银联、杭州巨星、正泰电气、上海宝松、上海比亚迪等众多参观团的高度评价。 拥有28年发展历程的亚洲国际动力传动展,不断创新求变,而唯一不变的则是深耕亚洲市场,服务全球贸易。今年展会还在世界顶级工业技术盛会——2018汉诺威工业博览会现场召开推介会,为欧洲乃至全球观众传递展会及中国工业发展的最新资讯。 转型升级,智造先行。亚洲国际动力传动展在智能制造的道路上不断前行,将与今年同期召开的亚洲国际物流技术与运输系统展览会、上海国际压缩机及设备展览会、上海国际工业零部件及分承包展、亚洲国际冷链设备及技术展览会和国际科创园区博览会打造“六展同台”的工业饕餮盛宴,助力中国动力传动行业“智慧腾飞”。 由中国液压气动密封件工业协会、中国机械通用零部件工业协会、德国汉诺威展览公司和汉诺威米兰展览(上海)有限公司共同主办的2018亚洲国际动力传动与控制技术展览会预计规模7万平方米,同期将举办十多场高峰论坛和技术研讨会,包括:中国国际汽车变速器及高效传动技术研讨会、工程机械供需对接交流会暨联盟省级发展论坛、VDMA智能制造论坛、中国石油化工装备高峰论坛和2018中国盾构机制造与技术高峰论坛等。 您的新闻联系人: 王婷 汉诺威米兰展览会(中国)有限公司新闻部 上海浦东新区银霄路393号 百安居浦东商务大厦301 邮编:201204 电话:021-50456700转253分机 传真:021-50459355 E-mail: pr@hmf-china.com 获取更多资讯请关注汉诺威展览官方微信:
