SKF is to supply Giant Main Bearings for World’s Tallest Observation Wheel
SKF has been awarded the contract to supply the two giant main bearings and related technologies for Caesars Entertainment Corporation’s (NASDAQ:CZR) Las Vegas High Roller observation wheel expected to soar at the heart of the world-famous Las Vegas Strip in late 2013. The 550-foot-tall wheel, eclipsing the famed 443-foot-tall London Eye, will be equipped with two SKF spherical roller bearings that will turn out to be the largest ever produced at the SKF manufacturing facility in Gothenburg, Sweden.
SKF observation wheel
The two custom-designed SKF spherical roller bearings (one within each side) will be virtually unprecedented in weight and size. Each bearing will weigh approximately 8,800 kg and be designed with 2,300mm outer diameter, 1,600mm inner diameter, and width of 630mm. Specially engineered features will include W26 lubrication holes in the inner ring, SKF NoWear-coated rollers, and PTFE coating in the bore. SKF additionally will incorporate advanced lubrication, sealing, and online condition-monitoring systems and take the lead in monitoring the bearings once the wheel is up and running.
SKF was awarded the contract by American Bridge Company (Coraopolis, PA, USA), which is responsible for constructing the 143m-diameter tension wheel. In addition to the two SKF bearing assemblies, the structure will consist of four steel support legs, a single braced leg, fixed spindle, rotating hub, 2m-diameter tubular rim, and 112 locked coil cable assemblies as spokes.
The Las Vegas High Roller is the centerpiece of The LINQ, a planned $550 million, open-air retail, dining, and entertainment district situated between Imperial Palace and Flamingo Las Vegas. Each of the wheel’s 28 supersize cabins (which themselves will revolve) will accommodate up to 40 people during a 30-minute ride.
The Las Vegas High Roller turns out to be the latest SKF big-wheel project in a growing portfolio of expertise. The Navy Pier Ferris wheel in Chicago similarly operates with two SKF spherical roller bearings and SKF Reliability Systems retains responsibility for ongoing proactive maintenance programs.
For more information visit www.skfusa.com.
Source: Product Design & Development
GGB自润滑轴承替代滚动轴承
GGB自润滑轴承替代滚动轴承(0)
This article, press release or announcement is translated from BearingNEWS (www.bearing-news.com) publications and adapted for the Chinese bearing industry professionals. << Replacing Roller Bearings with GGB Plain Bearings >> 当今GGB轴承技术提供的先进滑动轴承与滚动轴承相比具备很多优势。当今GGB轴承技术提供的先进滑动轴承与滚动轴承相比具备很多优势。 除了它们的简单设计和成本效益,滑动轴承提供更大的负载能力,更大空间,重量更轻,更紧凑的设计节省重量。此外他们补偿偏差,减少边缘载荷和抑制噪声和振动。因为它们不包含运动部件,轴承也提供更安静的工作环境,更可靠的性能,并且只需要很少维护。 这些优势是由设计工程师在广泛应用滑动轴承替换滚动轴承来实现的。这些应用包括风力涡轮机,农业设备,转向系统,空调压缩机,发动机摇臂,节流阀,变速箱和传动系统,和头目,其中。潜在应用包括海上浮式生产储油系统,制动机构,发电机和起动机。 滑动轴承也不是适合所有应用。尤其是在需要超低摩擦和/或高精度轴位置。但是在涉及高载缓慢的振荡运动中滑动轴承就显示出了优异性,因为滚动轴承的滚动部件脱落可能会导致过早失效。 用GGB轴承取代传统的滚动轴承可以给用户提供技术和竞争优势。更大的接触面积提供高承载能力和抗疲劳破坏,冲击和边缘载荷。轴承的摩擦特性也抵抗惯性和高速滑行,滚子轴承的主体,他们容忍偏差优于许多滚动元件设计。 紧凑的整体结构和较小的外壳,节省空间和重量。简单的压入配合几乎消除了安装的潜在损害。转换为滑动轴承还可以降低部分成本,低风险装配。 完整替换滚动轴承与普通轴承的文章,请点击 http://machinedesign.com/article/plain-bearings-outperform-rolling-element-bearings-0407 更多信息请联系 china@ggbearings.com
EMT bi-metallic bushing
EMT bi-metallic bushing(0)
EMT bi-metallic bushing  is suitable for high load, lower speed oscillation & rotation movement. EMT Brief Description EMT bi-metallic bushing is formed from steel strips with alloy lining material. The alloy lined surface can be machined oil grooves, holes, formed Indentations etc according to different application. It is suitable for high load, lower speed oscillation &
EX Tri-layer low maintanence plain bushings
EX Tri-layer low maintanence plain bushings(0)
EX Tri-layer low maintanence plain bushings has good physical & mechanical properties, also has certainly chemical properties. This material has good machining performance if required. EX Brief Description EX tri-layer low maintanence plain bushing have a base of lower carbon steel, onto which a porous bronze layer is sintered. Acetalcopolyer (POM) is impregnated into the
The largest bearing cage manufacturer in China
The largest bearing cage manufacturer in China(0)
Liaocheng Xinxin Golden Empire Bearing Cages Technology Co., Ltd is a professional bearing cages manufacturer, and it is famous for its large scale and premium brand. Since foundation in 1985, GEB had been developed steadily. Now GEB has thousands of workers, construction area is 99500㎡, total assets is 232 million RMB, and annual sales is
LYC launched the domestic most complicated rolling mill bearing
LYC launched the domestic most complicated rolling mill bearing(0)
On July 7, LYC Bearing Corporation launched the domestic most complicated high-precision shell ring rolling mill bearing and delivered to a domestic well-known heavy machinery enterprise, thus became the only bearing manufacturer able to produce this kind of bearing. According to Sun Jianxiu, deputy general manager of LYC Bearing Corporation, the bearing has a diameter
© 2016 BEARING NEWS All rights reserved.
