EMT bi-metallic bushing is suitable for high load, lower speed oscillation & rotation movement.
EMT Brief Description
EMT bi-metallic bushing is formed from steel strips with alloy lining material. The alloy lined surface can be machined oil grooves, holes, formed Indentations etc according to different application. It is suitable for high load, lower speed oscillation & rotation movement.
EMT Material Characteristics
| Part No | EMT-1 | EMT-2 | EMT-3 | EMT-4 |
| EMT Structure | asdasd | |||
| Backing | Steel | Steel | Steel | Steel |
| Alloy | CuPb10Sn10 | CuPb24Sn4 | CuPb30 | AlSn20Cu |
| Corresponding Code | SAE-792(SAE797). JIS-LBC3. |
SAE-799. JIS-LBC6. |
SAE-48. JIS-KJ3 |
SAE-783. JIS-AJL. |
| Clevite F100. GGB-SY. FMl HF-2F. Glyco 66. |
Daido L23. Glyco 68 | FM TR-20. Glyco 74. | ||
| Max Load Capacity P | 150N/mm2 | 130N/mm2 | 120N/mm2 | 100N/mm2 |
| Max. Speed | ||||
| Greaes Lubrication | 2.5m/s | 2.5m/s | ||
| Oil Lubrication | ||||
| Max Speed | 10m/s | 10m/s | 15m/s | 25m/s |
| Maximum PV Value | ||||
| Greaes Lubrication | 2.8N/mm2 · m/s | 2.8N/mm2 · m/s | 2.5N/mm2 · m/s | |
| Oil Lubrication | 10N/mm2 · m/s | 10N/mm2 · m/s | 8N/mm2 · m/s | 6N/mm2 · m/s |
| Coefficient of friction | ||||
| Grease Lubrication | 0.05~0.15 | 0.06~0.16 | ||
| Oil Lubrication | 0.05~0.12 | 0.05~0.15 | 0.06~0.17 | 0.06~0.17 |
| Max Working Temperature | ||||
| Greaes Lubrication | 150℃ | 150℃ | 170℃ | 150℃ |
| Lubrication | 250℃ | 250℃ | 250℃ | 250℃ |
| Alloy Hardness | 60~100HB | 45~70HB | 30~45HB | 30~40HB |
EMT Lubrication Design
EMT Split Gap Design
EMT Oil Hole Design
Oil Hole is necessary to design if EMT have lubricated sufficiently; the following oil hole design is recommended, which is also suitable for EMT series without special requirements.
| Bushing O.D. (D) | Φ14>D ≤ 22 | Φ22>D ≤ 40 | Φ40>D ≤ 50 | Φ50>D ≤ 100 | Φ100>D ≤ 180 |
| Oil Hole Diameter (mm) | 3 | 4 | 5 | 6 | 7 |
Oil hole location should keep away from the split gap & loading area, and in favor of oil-taking.
EMT Application
EMT-1:Advantageous in high load carrying capacity, anti-impact, lower wear. Suitable for Mid-load capacity & Mid-higher Sliding velocitie . Bushings for Gearbox, Rocker arm, King Pin, transmission etc .
EMT-2:Higher fatige strength & load carrying capacity, goos running characteristics at higher sliding velocities. Suitable for Mid-load capacity & Mid-Sliding velocitie . Bushings for lubricating oil pumps . After surface specifical treatment, Bushings for Main bushes of high speed internal-combustion engine, Connecting Rod etc .
EMT-3:Very Good sliding Characteristics, good anti-seizure property, special material, Punched oil grooves & oil pockets are not feasible. Bushings suitable for hydraulic Pump,automatic gearbox . After surface specifical treatment, bushings for main bushes of high speed, medium-low load internal-combustion engine, Connecting Rod etc.
EMT-4:Mid fatige strength & load carrying capacity, very good fatige strength & load carrying capacity, very good sliding characteristics . Bushings for half-bearing of high speed, lower load internal-combushtion engine, aircomressor, refrigerator, hypoid gearbox, hydraulic pump, gearbox etc.
Contact Details:
Jiashan Epen Bearing Co.,Ltd
No 161 ChengGong Road. Hui Min Street
Jiashan Zhejiang China
PostCode: 314100
T: +86 573 84824388
F: +86 573 84824386
Http: www.cnepen.cn
Email: [email protected]
